WLC 5508 connectivity issues
vito.nozza
Frequent Visitor
Frequent Visitor
I am installing a 5508 into an Alcatel environment.  The APs are 1131, the WLC 5508 however the client opted for Alcatel switches.  I already noticed an incompatability between switches when trying to connect fibre links.  Has anyone ever heard of these issues?  I tried configuring the mgnt port to VLAN specific only however I caannot ping it nor the default gateway when signed on via console.
Thx
Scott Pickles
Level 7
Level 7
Vito -
I've never used Alcatel switches, so I don't know what encapsulation they use for trunks.  Just remember that if you place the management interface for the 5508 into the native VLAN by specifying a tag of '0', then make sure that VLAN is also specified as the native VLAN on ALL trunks between the AP and the controller.  If an Alcatel switch uses a proprietary tagging method (like Cisco used to use ISL) where ALL frames are tagged, then you will have to specify the VLAN tag on the management interface.
If I am somehow off on what's going on here, perhaps you could elaborate on what you mean by "incompatability between switches when trying to connect fibre links".
Scott
Thx Scott. That could be the issue. I have placed both the WLC and the switch on a specific Vlan that I assigned for Management. I cannot ping the WLC.
I will do some research on the VLAN and Trunk specifics of Alcatel and see what I find.
BTW, I warned the client that the mixed platform might cause some issues.
Thx
Vito Nozza, BA, BCOM,
CISSP,CISA
Sr. Network Design Consultant
4000 Victoria Park
Toronto, Ont
t. 647.747.0417
m. 416.953.7463
e. vito.nozza@rci.rogers.com
