WLC 5508 custom syslog port
bkoch1
We're using a Kibana server that utilizes udp port 1514, instead of the normal port 514. There doesn't appear to be a place to specify a custom port number. Does anyone know of a place to change this? If not, is Cisco going to provide a software fix for this? I can do it on our ASA easily.
Rasika Nayanajith
Unfortunately you cannot change syslog port in any of the legacy controllers (5508/2504/etc). Here is a post on the same topic
https://supportforums.cisco.com/thread/2239795
If it is NGWC (like 3850,etc) you can do this as it runs on IOS-XE instead of Aironet software image.
Rasika
**** Pls rate all useful responses ****
