11-06-2018 01:45 PM - edited 07-05-2021 09:25 AM
Is it possible to use same IP addresses for redundancy management IP address pair and the regular management IP address pair on WLCs?
Solved! Go to Solution.
11-06-2018 02:42 PM
Management & Redundancy-management should be on same subnet. Each unit need to have unique redundancy-management IP address & management IP address is shared between units.
Something like below
(WLC) >show interface summary
management LAG 1000 x.x.0.200
redundancy-management LAG 1000 x.x.0.201
redundancy-port - untagged 169.254.0.201
(WLC-Standby) >show interface summary
redundancy-management LAG 1000 x.x.0.202
redundancy-port - untagged 169.254.0.202
Rasika
*** Pls rate all useful responses ***
11-06-2018 02:42 PM
Rasika
11-12-2018 08:03 AM
awesome, thanks for the help.
