WLC 5508- how to setting up with Web auth with 2 profile
Ben Lim
Hi Guys,
I wanted to control the 2 different profile to access internet with Cisco default landing page is that possible??
Example:
When connnected the SSID will redirect to Cisco landing pages
Cisco landing pages will differentiate there is member or guess with the password key in.
Member can access internet for 30 minute
guess only can access internet for 15 minute
Scott Fella
You can't use a single SSID and try to control various types of users with just a WLC. With ISE you can, but your almost better having two separate SSIDs and splash page. Where are these usernames defined?
You can use a 3rd party software both paid and free to possibly manage this better.
-Scott
Scott Fella
Just some notes on WebAuth in the WLC. The timeout is specified per SSID so there would be no way to set a timeout unless you use a radius server and send a radius attribute to the WLC to set the session timeout.
So we really need to know if you have a radius server, is the radius server tied to Active Directory or is the plan just using the WLC for everything.
-Scott
