wlc 5508 issue with netflow
ivan.martin
I have a wlc 5508- 8.5.171.0 with flex connect central auth local switching. WLC with flex connect deployment will support stealthwatch v7.3 (flow collector for netflow)?. I have more of 500 AP's connected.
Thanks. Ivan.
balaji.bandi
I know with DNAC and Stealthwatch possible : (kind of your requirement never deployed)
please check below URL may help you :
https://www.cisco.com/c/en/us/td/docs/wireless/controller/technotes/8-8/AVC_8point8_dg.html#pgfId-82568
BB
Hi balaji
My wlc doesn't has dnac. Might it possible support (flex connect local switching) with stealthwatch v7.3?
Regards, Ivan.
If I'm not mistaken, Netflow with Flexconnect together is not supported. Maybe with central switching, but typically the WLC is the flow exporter.
Actually I found the answer:
https://www.cisco.com/c/en/us/td/docs/wireless/controller/8-10/config-guide/b_cg810/wireless_quality_of_service.html#netflow
Quote:
Restrictions for Using Netflow
The enhanced template is supported only on Cisco 3504, 5520, and 8540 WLCs.
NetFlow is not supported on Cisco Virtual Wireless Controller (vWLC).
FlexConnect mode is not supported.
IPv6 traffic is not supported.
Only one collector and exporter each can be configured.
