WLC 5508 issue
jguremka1
Level 2
Level 2
We already have WCL 5508 setup with several SSIDs. We plan to create a new one and assign to new VLAN. However:
1. About 240 devices, laptops, IPods, etc will be connecting to that single SSID - is there any way to resolve that? I don't want to create multiple vlans and ssids for 30 devices.
2. I would like to create ACCT and Service SSID and have them access different vlans: for example
ACCT should have access to printer, server, Internet access
Service only Internet and server access.  Can I use ACL in WLC 5508? WLC 5508 is connected 8x to 3750 > 4900 > ASA 5510. There are only 2 and total would be 5 ACC list on it. Is this will be better idea to put ACC list on 3750 or 4900 or even ASA?
I am new to WLC controller and trying to figure it out asap. Thank You.
-John
Rasika Nayanajith
Hi John,
Your distribution layer where SVI defined is the best place to use ACL to control traffic. WLC is not a good place.
Would you be able to clarify your first query little bit more. I did not understand what is your requirement
Rasika
**** Pls rate all useful responses ****
Hi Rasika,
I appreciate your response and BIG THANK YOU!
2. so the ACL should be applied on Cisco 4900 since this is core switch for the specific VLAN that is used by the SSID configured on WLC 5508 - right?
1. I am worry about performance when 240 devices will be connected to one SSID (one vlan). Is there any way to fix that on WLC 5508. I have seen AP Group VLANS with WLC controllers - dont know if that would help here.
For now I created ACL on WLC5508 for now, but I am able to ping from 10.2.91.0 SSID all other vlans. This ACL should prevent accessing other vlans besides:70 101 115 and 91 which is assigned to that SSID.
I think ICMP is allowed to access all VLANS so thats why I am able to ping all networks, but besides ping anything else should be dead - right?
Hi John,
1. 240 devices per SSID is not a huge number. If you are concern about number of IP addresses available in a single vlan, you can always use interface group(or vlan select feature) to map multiple vlan to the same SSID. Refer below for better understanding of that feature
http://mrncciew.com/2013/01/27/understanding-vlan-select-feature/
AP-Group is another option, but above is much easier from administration point of view.
2. Yes, 4900 seems like best place to control inter-vlan traffic as that is the place where you define L3 interface (or gateway) of each of these user vlan
Rasika
