WLC 5508 - management frames without DSCP marking
Heinz Kern
Level 4
Level 4
hello,
we are facing an issue that our wireless lan controller (5508 with version 7.6.100) doesn´t mark management frames (e.g. reassociation repsonse - necessary for roaming) with CS6. therefore some of them are dropped leaving the clients not to roam...
does anybody have an idea? in my view it can only be a biug because it´s noit possible to reconfigure this....
thx
10 Replies 10
Scott Fella
That was a short lived code. You should upgrade to v7.6.130.0 as that was the stable release of v7.6.
-Scott
-Scott
good input
I'm curious is your WLC configured with the management vlan of the wlc to native and on the ports to the controller are you trusting cos ?
no it´s trunked on a port-channel. nevertheless we are trusting dscp
Likly you are losing 802.1p tag because you aren't trusting cos and then it gets written down on dscp. Trust cos on the trucks to the wlc and test again.
That aside I don't think management frames actually get marked .. I need to check on that
we are seeing managemt frames getting marked on Wism. i strongly believe they were marked in the past also on 5508. moreover frames are getting marked when they arinitiated by the AP
if we trust CoS frames are getting marked because it contains the dot1p tag. the switch generates the dscp-value out of it. but we want to trust dscp.
we see also a very strange behaviour when trusting COS that sometimes a reassociation request has dot1p value 2 and the next one has 5. so it seems that the tag is there, but not working properly.
changing to CoS in general would mean testing the whole infrastructure for voip over wireless lan again. and i don´t want to do that
Are you referring to the inner DSCP packet or the outer capwap DSCP marking ?
we are talking about management frames. they have only one dscp value
upgrade to 7.6.130 - the same behaviour
downgrade to 7.3.112 - DSCP values existing correctly
we didn´t test 7.6.100 deeply for QoS as we did for 7.3.112....not the best approach
