WLC 5508 Problem
sudeesh79
Level 3
Level 3
Hi All,
I have a WLC 5508, its PS1 and PS2 are OFF state, SYS is blinking amber and ALM is continues amber,
Its port s are not coming UP and I am not able to access the Controller, All ports are physically down and
in console nothing is showing when I connect through the console cable.
If anyone knows the issue please advise,
thanks
Amjad Abdullah
in the guide it says if SYS is blining amber and ALM is continuous amber then it is internal voltage error.
Internal Voltage Error:
•SYS blinks amber.
•ALM is continuous amber.
Reference: http://www.cisco.com/en/US/docs/wireless/controller/5500/install/guide/ctrl5500.html#wp35245
If your power source is OK then it seems the internal power is faulty and you need RMA.
Amjad
Rating useful replies is more useful than saying "Thank you"
Amjad Abdullah
•SYS blinks amber.
Amjad
Thanks for your reply,
As you said it seems internal power is faulty..
thanks
