wlc 5508 upgrade problem from 7.0.116.0 to 7.0.235.3
We have two WLC model 5508 with the follwing information
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Product Version.................................. 7.0.116.0
Bootloader Version............................... 1.0.1
Field Recovery Image Version..................... 6.0.182.0
Firmware Version................................. FPGA 1.3, Env 1.6, USB console  1.27
Build Type....................................... DATA + WPS + LDPE
System Name...................................... WLC-IDB-3
System Location..................................
System Contact...................................
System ObjectID.................................. 1.3.6.1.4.1.9.1.1069
IP Address....................................... 10.80.2.250
Current Boot License Level....................... base
Current Boot License Type........................ Permanent
Next Boot License Level.......................... base
Next Boot License Type........................... Permanent
Configured Country............................... SA  - Saudi Arabia
I tried to upgrde the software version to 7.0.230.0 or 7.0.235.3 but wlc displayed the following message
ERROR: Incompatible SW image.ERROR: Please install the Data Payload Encryption licensed image
please i need the necessary steps to resolve the problem.
Regards ,
Leo Laohoo
abwahid
Level 4
Level 4
This issue occurs because the Controller has an LDPE image installed, which is only needed in Russia where Data DTLS Payload Encryption is regulated by the Government.  Cisco only recommends using this image if you reside in Russia.  To resolve this issue and put the standard image on
To follow the steps go through the below link
http://sigkillit.com/tag/error-incompatible-sw-image-error-please-install-the-data-payload-encryption-licensed-image/
