WLC 5520 not work with GLC-T
mohammad saeed
Level 5
Level 5
Hi Guys
I have wlc 5520 virtual softeare. I connected GLC-H IN port1 and GLC-LH in port2 but two ports not comming up even after reboot!
 Whatcould be the issue?
Thnks
Mk saeed
Sandeep Choudhary
Make sure to use of GLCT on port#1 and a GLC-LH-SMD on port#2 will sort the issue, both ports will be up.
Info: Early versions of the 8.1 had bugs when using SFP. Also try plugging a GLC-T in port 1.
BUG: https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvc13175/?referring_site=bugquickviewredir
Dont forget to rate helpful posts
