WLC 6.0.182.0
Darren Ramsey
Level 4
Level 4
Anyone running 6.0 and/or ClientLink? Let's hear some feedback...
34 Replies 34
After I upgrade WLC to 6.0.182.0, all APs do not show up, how to get them back?
Thanks!
Check the time of your WLC, it may not have sync-ed with an NTP source.
Set the correct time or NTP source and check again.
Are your access points at remote sites? If so can a machine on the other network ping the controller?
Ok now, I added a new IP scope last week and it looks like all APs received ip from this new scope - different from managment-port.
john.gudmann
have now been running 6.0.182 for some weeks now. The most ignoring thing is that audit goes' wrong with the guest user and local net use.. If you make a guest user via wcs (lobby) and save user on controlle the user get save as a local net user on the controller but the wcs keeps the user in the guest user database.
