WLC 8540 LAG connectivity with ACI
Hi All/Rasika,
I am deploying WLC8540 in ACI Environment.
Issue; From ACI I can not see the ports up its showing Suspended.
Any advise would be highly appreciated.
Thank you.
Vimal.
Hi Vimal,
Hope you configure etherchannel mode "ON" ACI side.
sorry,Haven't done any work with an ACI setup to give you some advice here.
Hopefully you will get some responses who familiar that kind of setup
Rasika
Hi Rasika,
Thank you very much for your reply, the problem was from ACI end.
Fixed now all good.
Will be posting lot of queries for ISE and WLC ....
jjj
Vimal.
I do have issues in WLC after moving from traditinal 6500 switch to ACI leaf .
issue 1) Getting packet drops while pinging the virtual ip address and no drops in the physical IP address .
Issue 2) The MAC address of the WLC is reported in EndPoint dampening and freezing .
