WLC 9800 guest redirection using LWA
O.Zang
Hi experts,
Hi have deployed a guest WLAN using Local Web authentication.
When I the user signs into the Guest WiFi and there is no automatic redirect to the Guest WiFi portal.
It Get redrect only if the user time only if the user typer and http request in the broswer.
 please advice how to me the automatic redirect via pops up works.
O Zang
Ensure you have HTTPs for the 9800 management enabled and this is there.
Device(config)# parameter-map type webauth global
Device(config-params-parameter-map)# webauth-http-enable
Guide for Web Auth config here:
https://www.cisco.com/c/en/us/td/docs/wireless/controller/9800/17-3/config-guide/b_wl_17_3_cg/m_vewlc_sec_webauth_cg.html
*****Help out other by using the rating system and marking answered questions as "Answered"*****
WLC does not redirect the HTTPS traffic (by default, version 8.x you can enable it)
If you are on an AireOS WLC you can use the command: config network web-auth secureweb
But highly don't recommend this as it can cause a performance hit on the whole WLC, also the user may be presented with the certificate warning page.
Modem Windows, Apple and Android devices utilise a http redirect to test if a captive portal is present.
Also confirm you are not using 1.1.1.1 as the virtual IP address
Thank for your reply  @Haydn Andrews
I am using C9800 and with 192.0.2.1 ( non routable ip) as Virtual ip.
I am trying to make the automatic redirect via pops up works when the user signs into the Guest WiFi.
OZang
