WLC 9800 Guest SSID web auth not redirecting
I have an issue with a guest ssid, where I have enabled it as a open network with web auth. Unfortunately no matter what I do, I cannot get it to redirect to the real "redirect for-login" URL. It redirects to the default one locally on the WLC. Here's the config:
parameter-map type webauth guestportal
type webauth
redirect for-login https://FQDN/portal/
redirect portal ipv4 1.2.3.4
ip access-list extended Pre-Auth-ACL
1 permit tcp any host 1.2.3.4 eq 443
2 permit tcp host 1.2.3.4 eq 443 any
5 permit udp any host 1.2.3.5 eq domain
6 permit udp any host 1.2.3.6 eq domain
30 deny ip any any
wlan FortiGuest 5 Guesttest
ip access-group web Pre-Auth-ACL
peer-blocking drop
no security ft adaptive
no security wpa
no security wpa wpa2
no security wpa wpa2 ciphers aes
no security wpa akm dot1x
security web-auth
security web-auth authentication-list Guest-AAA-Auth
security web-auth parameter-map guestportal
Is there something that I am missing?
I do not get the "ACL plumb" part in my debug trace and under the "Layer 3 authentication and redirection process" I get dst other than my external web server:
2025/02/14 10:24:48.153625090 {wncd_x_R0-0}{1}: [webauth-httpd] [15400]: (info): capwap_900000b7[7209.7de5.0bb4][ x.x.x.x]Parse GET, src [x.x.x.x] dst [142.251.209.131] url [http://connectivitycheck.gstatic.com/generate_204]
Do you know what that could mean I'm missing?
is a url that clients use in order to validade internet access. The redirect is done based on this access attempt.
Do you have HTTP enable on the WLC?
yes, ip http server and ip http secure-server is enabled on the WLC.
Under the Client -> General -> Security Information, I can see that the URL Redirect ACL is WA-v4-int-x.x.x.x (x.x.x.x is the web server IP), so something is happening, but it won't redirect to the correct webpage.
