WLC 9800 issues with projectors
hfaisca
I'm having some issues of comunication with a WLC 9800 and Projectors from Epson brand (Epson 955w), this projects are trying to reauthenticate in every 10 minutes and sometimes this equipment disconect completly.
I tried the following:
- Disable FT from ssid.
- Increase the session timeout to 86400 sec.
- Since this project conect with a usb antenna via wifi, i confirmed if 803.11b/g/n are enabled. the data rate 11mbps are mandatory and data rates bellow.
I will attach the logs from two device to this topic.
This is the log i got when completly disconnected.
2023/09/06 10:34:31.071 client-orch-sm Controller initiated client deletion with code: CO_CLIENT_DELETE_REASON_IPLEARN_CONNECT_TIMEOUT. Explanation: Controller did not learn client IP address in the allowed time. Actions: Check DHCP server and client IP configuration. Validate if DHCP required is set and client is performing DHCP negotiation. If all is correct, collect RA traces and EPC
marce1000
  - Have an overall checkup of the controller configuration with the CLI command show tech wireless ; feed the output into :
                                    https://cway.cisco.com/wireless-config-analyzer/
    Check  the current software version on the 9800 controller , correlate this with :
                                   https://www.cisco.com/c/en/us/support/docs/wireless/catalyst-9800-series-wireless-controllers/214749-tac-recommended-ios-xe-builds-for-wirele.html
 M.
Leo Laohoo
I do not care what Epson says but all data rates must be enabled and must be set to "default" values.
