WLC Active Not in use
uzochikwa
Hi All,
Can someone please tell me if wlan controller license can still be used for AP connection if it says: active not in use. Its an evaluation license
U
If the license is within the valid period yes. On my case, for example, as the evaluation period expired, it shows as Inactive, whilst the permanent license shows as Active, In-use.
-If I helped you somehow, please, rate it as useful.-
Thanks Flavio
Hi Flavio,
Should Layer 2 or Layer3 Dacl be applied or is supported in flexconnect or not? Also is Dacl supported with flexconnect?
