WLC AIR-CT3504 SSH public key authentication
Felix Zukerman
Hi guys,
Is it possible to configure SSH public key authentication
Couldn't find any options via CLI or GUI for entering a public key.
For example, on switches, it is as follows:
ip ssh pubkey-chain
username TEST
key-string [Enter]
ssh-rsa AAAAB3NzaC1yc2EAAAADAQABAAACAQO5583UrTL73Jv0qEJonUP
t20gWdWlZtbHot0NA4WIVdIFmCaydPDT/Aneqajndza64V4eVB0fJsW1y523LAu3s5zJ1CkV/V
bshYaqIr4v6zMng/PFCqeFkiNIHAhqcbVCBEFEDRTWERFDSF345436SFsdfsdfW#EFDSF
sdkl8643nncv5678jnd@#$%$tD+sjCuJfcZZa0uMQjAbVoj5d8UEhztzRxmK1ZU25vaHykw
DRtgEv8fVW+uT5ToszFaRTwu7O9GoFvSXbgR3HcwdsZ4g5Oup7Esn8H6umyZZw=
Felix
Best regards, Felix
5 Replies 5
Mark Elsen
 - Check if this document can help :
               https://www.cisco.com/c/en/us/support/docs/wireless-mobility/wireless-lan-wlan/68789-ssh-enable-ap.html
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Hi @Mark Elsen ,
Public key authentication is not covered.
It contains an overview of the basic and general SSH settings.
Best regards, Felix
 - The ap may have auto-generated a  public-key , check this with : show running-config  (and or share here)
 M.
       Beauty and terror
      Just keep going
       No feeling is final
 My goal is to add our public key (the host I SSH from) to a WLC and use it for SSH authentication instead of a password.
Best regards, Felix
I don't think that is supported on access points. M.
       Beauty and terror
      Just keep going
       No feeling is final
