WLC and AP 2602 Join Failed
probopurwo
Hi all,
anyone can help me for this log ?
Translatiuokng "CISCO-CAPWAP-CONTROLLER"...domain server (255.255.255.255)  o ooi po iopo
*Mar  1 00:00:57.527: %CAPWAP-5-DHCP_OPTION_43: Controller address 172.16.250.252 obtained through DHCP
*Mar  1 00:00:57.527: %CAPWAP-3-ERRORLOG: Did not get log server settings from DHCP.
*Mar  1 00:01:06.527: %CAPWAP-3-ERRORLOG: Could Not resolve CISCO-CAPWAP-CONTROLLER
*Mar  1 00:01:06.527: %CAPWAP-3-ERRORLOG: Discovery response from MWAR 'WLC_TASPEN_01'running version 7.0.116.0 is rejected.
*Mar  1 00:01:06.527: %CAPWAP-3-ERRORLOG: Failed to decode discovery response.
*Mar  1 00:01:06.527: %CAPWAP-3-ERRORLOG: CAPWAP SM handler: Failed to process message type 2 state 2.
*Mar  1 00:01:06.527: %CAPWAP-3-ERRORLOG: Failed to handle capwap control message from controller
*Mar  1 00:01:06.527: %CAPWAP-3-ERRORLOG: Failed to process unencrypted capwap packet from 172.16.250.252
*Mar  1 00:01:16.527: %CAPWAP-3-ERRORLOG: Discovery response from MWAR 'WLC_TASPEN_01'running version 7.0.116.0 is rejected.
*Mar  1 00:01:16.527: %CAPWAP-3-ERRORLOG: Failed to decode discovery response.
*Mar  1 00:01:16.527: %CAPWAP-3-ERRORLOG: CAPWAP SM handler: Failed to process message type 2 state 2.
*Mar  1 00:01:16.527: %CAPWAP-3-ERRORLOG: Failed to handle capwap control message from controller
*Mar  1 00:01:16.527: %CAPWAP-3-ERRORLOG: Failed to process unencrypted capwap packet from 172.16.250.252
*Mar  1 00:01:26.527: %CAPWAP-3-ERRORLOG: Discovery response from MWAR 'WLC_TASPEN_01'running version 7.0.116.0 is rejected.
*Mar  1 00:01:26.527: %CAPWAP-3-ERRORLOG: Failed to decode discovery response.
*Mar  1 00:01:26.527: %CAPWAP-3-ERRORLOG: CAPWAP SM handler: Failed to process message type 2 state 2.
*Mar  1 00:01:26.527: %CAPWAP-3-ERRORLOG: Failed to handle capwap control message from controller
*Mar  1 00:01:26.527: %CAPWAP-3-ERRORLOG: Failed to process unencrypted capwap packet from 172.16.250.252
*Mar  1 00:01:26.771: %CDP_PD-2-POWER_LOW: All radios disabled - NEGOTIATED WS-C3560X-24P (70ca.9be7.5c17)
*Mar  1 00:01:36.527: %CAPWAP-3-ERRORLOG: Discovery response from MWAR 'WLC_TASPEN_01'running version 7.0.116.0 is rejected.
*Mar  1 00:01:36.527: %CAPWAP-3-ERRORLOG: Failed to decode discovery response.
*Mar  1 00:01:36.527: %CAPWAP-3-ERRORLOG: CAPWAP SM handler: Failed to process message type 2 state 2.
*Mar  1 00:01:36.527: %CAPWAP-3-ERRORLOG: Failed to handle capwap control message from controller
*Mar  1 00:01:36.527: %CAPWAP-3-ERRORLOG: Failed to process unencrypted capwap packet from 172.16.250.252
*Mar  1 00:01:46.527: %CAPWAP-3-ERRORLOG: Discovery response from MWAR 'WLC_TASPEN_01'running version 7.0.116.0 is rejected.
*Mar  1 00:01:46.527: %CAPWAP-3-ERRORLOG: Failed to decode discovery response.
*Mar  1 00:01:46.527: %CAPWAP-3-ERRORLOG: CAPWAP SM handler: Failed to process message type 2 state 2.
*Mar  1 00:01:46.527: %CAPWAP-3-ERRORLOG: Failed to handle capwap control message from controller
*Mar  1 00:01:46.527: %CAPWAP-3-ERRORLOG: Failed to process unencrypted capwap packet from 172.16.250.252
Not in Bound state.
*Mar  1 00:02:01.527: %CAPWAP-3-DHCP_RENEW: Could not discover WLC using DHCP IP. Renewing DHCP IP.
Nedd your advice guys, Thanks ...
stefan.angerer
WLC Code 7.0.116.0 does not support the 2600 series APs, you need 7.3+
regards
Stefan
Thanks stefan ...
i'll try first .. thanks you
