WLC AP authentication for expired built-in certs
gpinero
Hi all, I'm facing a problem with old ap's. The builtin certificate was expired and it's doesn't register. Temporal workaround was change date of the WLC. Now I like to resolve this issue with best practices.
Can I use ISE to auth the access points?
I'm reading about LSC and disable the use of certificates, only auth the AP with MAC address? Is this options secure? what are the problems with LSC?
I have an enterprise CA... I can use it? what is the best form of do that
Can you guide me to the best maner to do the AP authentication to the controller?
CCNP R&S, CCNP Security, CCNA CyberOps
Mark Elsen
- Try :
(WLC)>config ap cert-expiry-ignore {mic|ssc} enable
M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
