WLC AP Failover
ak7246
Hello Friends,
We recently installed 2 4402 WLCs. I configured Mobility group and split the APs between 2 WLCs by configuring Primary Controller on each AP. No secondary or tertiary Controller was configured.
Now when WLC1 goes down, the APs on WLC1 register with the WLC2. However, when WLC1 comesback up the APs don't fall back to WLC1. They stay associated with WLC2 until they are rebooted.
is this normal or am i missing anything?
thanks
Anand
16 Replies 16
Leo Laohoo
Hi Anand,
Configure the Secondary Controller and this should be fine.
gamccall
Level 8
Level 8
Make sure AP Fallback is turned on. "config network ap-fallback enable", or it's under the Controller:General tab in the GUI.
As gmccall pointed out ...
If you set AP fall back the APs will fall back to their main controller once the controller comes back online. Do keep in mind, this may be a slow process. They dont all jump at once ..
you can find this on your controller @:
Controller (TAB on dashboard) --> AP FALL BACK (drop down ENABLE)
thanks for your replies guys. Actually the AP fall back is enabled. the mobility group is also configured however in the mobility summary the control path shows down and mping and eping fails between the controller. The controller management IPs are in same subnet and no firewall blocking the required ports for mobility.
thanks
Anand
If you can't find any other problems that might cause this (i.e. routing or ACL issues) you might try deleting and recreating your mobility group.
thanks Gabrial.
It turns out that i had the local WLC in Local Mobility Group and other WLC in the one i created. doh!!!.
it works now. I changed the names so they both are in same group.
I appreciate all your help.
thanks
Anand
We currently have only one WLC on our network. Is it possible to configure the AP's to use default settings when a WLC goes down or is not available? Or do we need a second controller?
I think your question is, "if the controller goes down, can the APs still service clients".
If that is your question, your anwser is no. If your controller does down so will the connecitivy to your APs (unless you use HREAP local switching).
Thank George, I am using HREAP local switching for all my WLAN's. What exactly is HREAP.
How can I safely test this during normal hours? Disconnect WLC from network?
Thanks Bob
Here is an HREAP design and deployment guide that should get you off and running:
http://www.cisco.com/en/US/products/ps6087/products_tech_note09186a0080736123.shtml
Introduction
Hybrid Remote Edge Access Point (H-REAP) is a wireless solution for branch office and remote office deployments. It enables customers to configure and control access points in a branch or remote office from the corporate office through a wide area network (WAN) link without deploying a controller in each office. The H-REAP access points can switch client data traffic locally and perform client authentication locally when the connection to the controller is lost. When connected to the controller, H-REAPs can also tunnel traffic back to the controller.
How do you plan on using HREAP? Do you have local / remote offices? If you plan to use this on an your internal hospital network you may want to rethink your design, if its large HREAP isn't a wise choice.
Also read the section on security. What are you using for layer 2 security for your wireless clients?
I will review that document.
Our deployment is very small, 4 units/hallways in our primary facility. The same in our remote offices. We use WPA2+PSK for security. All our facilities are connected via ptp IPSec vpn using Cisco Routers over Verizon FIOS.
You say if it's a large enviroment, HREAP is not a good choice. Why is that?
When I mean large enviroment i mean a large hospital all deployed in HREAP APs. Funny, i had another engineer wanting to design his entire hospital with HREAP.
In my consulting days i designed and deployed 50 remote offices with HREAP in NYC. Works great for remote offices so long as you arent using 802.1x....
I understand there is extra processing used when deploying HREAP (per TAC), this is why they limited the amount of access points in HREAP (in the ealry days 2 - 3 years ago), but since then they have opened it up.
George, your input is much appreciated. I will mostly likely add more controllers in the future, but for now, this will work considering our size.
One last question, H-REAP was designed for remote offices, but will it work in the central office as well?
Thanks again!
yup, but keep in mind, like the remote offices, if their apps reside central wise what value is there to wireless if you cant get to your apps should the central go down?
Back to the offices i did .... their apps/server farm resided in a local off site. If their central went down their wireless still worked, but their apps were hosed... so they could gain access
to wireless but go nowhere....
