WLC Applying cached RADIUS Override values for mobile
kurosknight
Hello!
We have a WiSM2 (version 7.4.110.0) with approx 200 APs. We are doing RADIUS authentication via a PacketFence backend. Everything usually works fine, but we are having an intermittent issue...
The WiSM2 gets its VLAN assignment for a client from the PacketFence server and does AAA override. If a client has not registered their device, go on one VLAN. Once they register, PacketFence disconnects them via RADIUS to the WiSM2, and then they should get their new VLAN assignment. This works fine in the majority of cases, but occasionally, after registering, the client disconnects and reconnects but is still put back on registration VLAN.
debug client mac shows this in the logs:
Applying cached RADIUS Override values for mobile 00:25:56:3d:f6:7b (caller pem_api.c:2210)
And I do not see the WiSM2 asking the PacketFence server for a VLAN assignment in the PacketFence logs.
Eventually, if the client stays disconnected long enough (5+ minutes), they can reconnect and get the proper VLAN assignment. I had previously opened a TAC about this, and they suggested a WiSM2 software upgrade and setting the Session Timeout on the WLAN to 900 seconds, which I did. This issue then disappeared for several weeks, but it has started happening again today (we saw it happen to about 15 clients throughout the day).
Anyone have any ideas on why this is happening, and how to stop the caching? Any thoughts would be greatly appreciated.
Here is the output from a show wlan of one of our WLANs we have seen this on:
WLAN Identifier.................................. 2
Profile Name..................................... BlitzNet
Network Name (SSID).............................. BlitzNet
Status........................................... Enabled
MAC Filtering.................................... Enabled
Broadcast SSID................................... Enabled
AAA Policy Override.............................. Enabled
Network Admission Control
  Client Profiling Status ....................... Disabled
   DHCP ......................................... Disabled
   HTTP ......................................... Disabled
  Radius-NAC State............................... Disabled
  SNMP-NAC State................................. Disabled
  Quarantine VLAN................................ 0
Maximum number of Associated Clients............. 0
Maximum number of Clients per AP Radio........... 200
Number of Active Clients......................... 538
Exclusionlist Timeout............................ 60 seconds
Session Timeout.................................. 900 seconds
User Idle Timeout................................ 300 seconds
User Idle Threshold.............................. 0 Bytes
NAS-identifier................................... WISM2_SDC
CHD per WLAN..................................... Enabled
Webauth DHCP exclusion........................... Disabled
Interface........................................ blitznet
Multicast Interface.............................. Not Configured
WLAN IPv4 ACL.................................... unconfigured
WLAN IPv6 ACL.................................... unconfigured
mDNS Status...................................... Disabled
mDNS Profile Name................................ unconfigured
DHCP Server...................................... Default
DHCP Address Assignment Required................. Disabled
Static IP client tunneling....................... Disabled
PMIPv6 Mobility Type............................. none
Quality of Service............................... Silver
Per-SSID Rate Limits............................. Upstream          Downstream
Average Data Rate................................   0                      0
Average Realtime Data Rate.......................   0                      0
Burst Data Rate..................................   0                      0
Burst Realtime Data Rate.........................   0                      0
Per-Client Rate Limits........................... Upstream          Downstream
Scan Defer Priority.............................. 4,5,6
Scan Defer Time.................................. 100 milliseconds
WMM.............................................. Allowed
WMM UAPSD Compliant Client Support............... Disabled
Media Stream Multicast-direct.................... Disabled
CCX - AironetIe Support.......................... Enabled
CCX - Gratuitous ProbeResponse (GPR)............. Disabled
CCX - Diagnostics Channel Capability............. Disabled
Dot11-Phone Mode (7920).......................... Disabled
Wired Protocol................................... None
Passive Client Feature........................... Disabled
Peer-to-Peer Blocking Action..................... Drop
Radio Policy..................................... All
DTIM period for 802.11a radio.................... 1
DTIM period for 802.11b radio.................... 1
Radius Servers
   Authentication................................ ipofradiusserver 1812
   Accounting.................................... Global Servers
      Interim Update............................. Disabled
   Dynamic Interface............................. Disabled
   Dynamic Interface Priority.................... wlan
Local EAP Authentication......................... Disabled
Security
   802.11 Authentication:........................ Open System
   FT Support.................................... Disabled
   Static WEP Keys............................... Disabled
   802.1X........................................ Disabled
   Wi-Fi Protected Access (WPA/WPA2)............. Disabled
   WAPI.......................................... Disabled
   Wi-Fi Direct policy configured................ Disabled
   EAP-Passthrough............................... Disabled
   CKIP ......................................... Disabled
   Web Based Authentication...................... Disabled
   Web-Passthrough............................... Disabled
   Conditional Web Redirect...................... Disabled
   Splash-Page Web Redirect...................... Disabled
   Auto Anchor................................... Disabled
   FlexConnect Local Switching................... Disabled
   flexconnect Central Dhcp Flag................. Disabled
   flexconnect nat-pat Flag...................... Disabled
   flexconnect Dns Override Flag................. Disabled
   FlexConnect Vlan based Central Switching ..... Disabled
   FlexConnect Local Authentication.............. Disabled
   FlexConnect Learn IP Address.................. Disabled
   Client MFP.................................... Optional but inactive (WPA2 not configured)
   PMF........................................... Disabled
   PMF Association Comeback Time................. 1
   PMF SA Query RetryTimeout..................... 200
   Tkip MIC Countermeasure Hold-down Timer....... 60
AVC Visibilty.................................... Disabled
AVC Profile Name................................. None
Flow Monitor Name................................ None
Call Snooping.................................... Disabled
Roamed Call Re-Anchor Policy..................... Disabled
SIP CAC Fail Send-486-Busy Policy................ Enabled
SIP CAC Fail Send Dis-Association Policy......... Disabled
KTS based CAC Policy............................. Disabled
Assisted Roaming Prediction Optimization......... Disabled
802.11k Neighbor List............................ Disabled
802.11k Neighbor List Dual Band.................. Disabled
Band Select...................................... Disabled
Load Balancing................................... Disabled
Multicast Buffer................................. Disabled
Mobility Anchor List
WLAN ID     IP Address            Status
802.11u........................................ Disabled
MSAP Services.................................. Disabled
Scott Fella
What do you see in the radius logs? You see the radius sending the correct vlan? Also look at the client on the monitor tab and see what vlan it is placed on.
-Scott
There is nothing in the RADIUS server logs. It is as if the WiSM2 does not talk to it for the 2nd request. The flow for a problem client is like this:
1. New client associates
2. WiSM asks RADIUS server for VLAN
3. RADIUS Server hasn't seen it, so it puts it on VLAN 84 (our registration VLAN)
4. Client goes through captive portal
5. RADIUS server sends disconnect client message to WiSM
6. Client disconnects, reconnects
7. WiSM2 puts it back on VLAN 84, when it should put it on a VLAN determined by the SSID. The WiSM2 never asks the RADIUS server for the VLAN again, until the client has stayed disconnected for 5+ minutes, and I see the message in the wism2 log that I wrote above.
In the vast majority of cases, step 7 works properly. That is, when the client reconnects, it asks the RADIUS server what VLAN to put it on (I see it in the RADIUS server logs). I see the second request come in, and the RADIUS server replies with appropriate VLAN for the SSID.
After they get their proper VLAN, this doesn't occur again. It is as if the RADIUS server caches the client's VLAN override attribute somewhere and uses that, rather than asking the RADIUS server.
Scott Fella
Well if you look at the client in the monitor tab, the reason it's still keeps the same vlan and IP is that the client is still in a run state. It's different of they register on SSID X and them they have to join SSID Y. Since your using the same ssid, your client has to be removed from the WLC. The session timer is a hard timer and when that expires (900 seconds is 15 minutes) then they are removed from the WLC db. The idle timer is when the client sits idle and when that expires then the client is removed from the WLC. Certain devices work different because some will send a disconnect to the AP and some don't. So the best thing to do to test is to use a device (laptop and iPad) and remove the info on the radius or captive portal so the device looks like a brand new unregistered device. Take a look at the client information in the monitor tab in the WLC and you will see the client in the RUN state and it will also tell you what vlan and IP address the client has. Then go through your registration and see what happens when the client is disconnected. If you still see the client in the WLC, then that's why.
-Scott
Hi Scott,
You are correct, after disconnection the client is remaining in the RUN state for both RADIUS NAC State and Policy Manager State.
Other than lowering the idle timeout to something like 30 seconds, is there a way for it to not cache RADIUS NAC state?
