WLC C9800 with 2 method authenticate L2 and L3
jewfcb001
Level 4
Level 4
Hi All
I try to configure 2 method for C9800-CL authenticate L2 and L3 authenticate .
L2 use mac filtering and L3 use web authenticate but I configure 2 method the client confuse and cannot connect to wireless
but if configure only 1 authentication method per ssid can do it . Can I configure 2 method per SSID?
Thank you .
Haydn Andrews
Suggest using RADIUS to do the MAC filtering as well as the WebAuth.
I have only done L2/3 together to have PSK on the SSID prior to the web Auth to stop DHCP exclusion and then WebAuth to do the T&Cs
*****Help out other by using the rating system and marking answered questions as "Answered"*****
@Haydn Andrews
Thank you for response.
You mean mac filtering (dot1x) and webauth with local ? and L2/L3 (Mac+Web) can configure or not?
Because the customer need 2 method with 1 SSID C9800 can do ?
