WLC code for point to point bridging
ewood2624
Level 3
Level 3
What is the best WLC code for point to point and point to multipoint bridging on a 2504 with 2602 APs? 7.2-7.4 had transparent vlan issues and I'm not sure if they were fixed in 7.5-7.6. We have 5-6 vlans that we are needing to bridge between a large open area. Also, are there any bugs with wireless mesh and ISE?
Rasika Nayanajith
You do not have many choices now, only 7.0.250.0, 7.4.121.0 & 7.6.110.0 codes are supported by Cisco. All other codes have been deferred by them.
I do not have configured those set-up to advise you specific to that. I would think 7.6.110.0 may have fixed whatever the known bugs in previous versions.
Rasika
**** Pls rate all useful responses ****
Rasika Nayanajith
Rasika
