WLC Configuration guide
Pranav Mhatre
Level 3
Level 3
Hi Guys,
Can you please share link from where can I get WLC configuration guide in PPT format , I need to use same for training purpose.
I was able to download PDF of same but I need PPT which would be simpler format.
7 Replies 7
Leo Laohoo
Go HERE.
Thanks Leo, However PDF is of 1094 pages.
I need basic configuration guide in short ppt format.
You might have to create that yourself.  Have you tried searching on Google to see if maybe someone has created one and is avaialbe on the Internet?
-Scott
-Scott
Hi Scott,
I did, Will have to make ppt on my own mostly.
That is correct.... many ppt that are out there are on different code versions that what you will be using, plus the screen shots vary between code versions at times due to ne features.  This gets confusing to an end user, if your planing on training them.  Customizing your own ppt is the way to go.
-Scott
-Scott
Your statement is self-contradicting.
First, you want to know where you can find a configuration guide.  Next you want the configuration guide to be SHORT.
Sorry, but I hate to break the news to you but you're dealing with CISCO products.  The Configuration Guides are always long.
If you want short and simple, try Netgear.
Hi Leo,
Thanks for ideas & Suggestions.
