WLC connection to Switches
huber
I have two installation with WLC 4402 to Cisco Switches 3750. The Connection is Fibre with GLC-SX and channeld. The Problem I have is, tha 10% of the Packets are underruns. Has anybody encounterred the same issue?
I also have two other installaions with 4402 and 4404 and the connected switches are 6509 and there it is working with G-Bics and SFPs.
Thanks for your help
5 Replies 5
ankbhasi
Hi Huber,
Can you paste the switchport configuration from 3750 switch on which 4402 controller is connected?
Ankur
Hi Ankur,
Here is the config snippet of te Port config.
SH1-2OG-SWI01#sh run int Po 1
Building configuration...
Current configuration : 201 bytes
interface Port-channel1
description *** sh1-2og-wlc01 ***
switchport trunk native vlan 4
switchport trunk allowed vlan 4,20,29,31
switchport mode trunk
end
SH1-2OG-SWI01#sh run int g1/0/1
Current configuration : 233 bytes
interface GigabitEthernet1/0/1
channel-group 1 mode on
end
SH1-2OG-SWI01#sh run int g1/0/2
interface GigabitEthernet1/0/2
end
SH1-2OG-SWI01#
Thanks your reply
regards
ray
Hi huber,
What i understand the config should look like this when using LAG. Because that is what you do i guess? So the allowed vlans should just be specified under the port-channel config.
?Each neighbor port to which the controller is connected should be configured as follows:
switchport
channel-group mode on
no shutdown
?The port channel on the neighbor switch should be configured as follows:
interface port-channel
switchport
no shutdown
I have a question at the same time. What native vlan shall i configure on the port-channel? My management vlan which is 50 in this case?
Thanks and best regards!
hajn1
Thanks for the reply. When you configure Port-channel, it will copy the commands to the Interface by which it is assigned. So the running config will look like this.
To your Question. The native VLAN should be the Managment VLAN of the Controller. I mean Segment in which the mgmt Interface of the Controller is.
huber,
Thanks a lot! I hope someone can answer the question you actually created this thread about.
