WLC Deleting Interface: Interface group is being used by AP Group
toupheng.her
When trying to delete an interface from an interface group, I am getting the error Interface group is being used by AP Group. Is there a way I can delete the interface?
George Stefanick
You have have to visit ap groups on that controller and remove the use of that interface. After that it will allow you to remove it from the interface section.
Under the WLAN tab, there is an WLAN SSID using the interface. Would it be an issue if I remove the it, and re-add the WLAN SSID?
Or you can select another interface freeing the one up you want to delete and then delete it .. key here is that the WLC wont delete a interface that is tied to a WLAN ..
__________________________________________________________________________________________
‎"I'm in a serious relationship with my Wi-Fi. You could say we have a connection."
