WLC ethernet bridge
Maurice Ball
Level 6
Level 6
I've a WLC 2106 and it is running IOS version 7.0.240. I am trying to setup a wireless mesh and used the ethernet bridge port on the MAP to extend the network. The wireless mesh works fine but I can not get the switch to work that is connected to the ethernet port on the MAP.
I'm using two different Access points. I'm using a Air Cap 3502i as the RAP and a Air Lap1142N as the MAP.
The switch port that is connected to the RAP and MAP is configured as the following:
switchport mode trunk
switchport trunk native vlan 2
switchport trunk allowed vlan 10,20,30,40
The RAP etherbridge port is enable and set to: normal
The MAP etherbridge port is enable and set to: Trunk,
native vlan is set to: 2
Vlan id 10
Vlan id 20
The wireless mesh between the RAP and MAP works fine. I can connect a device to the MAP wirelessly and access the network with no problem but I can not get anything to work that connects to the switch that is connected to the MAP ethernet port.
Could someone please tell me what I'm doing wrong?
Scott Fella
I would open a TAC case as this is a bug. I don't recall what code it stopped working but I know it doesn't work also in the v7.3 & v7.4
-Scott
Scott Fella
-Scott
Maurice Ball
Level 6
Level 6
thanks for the help.
