WLC ethernet bridge
filip00011
Level 3
Level 3
I want to achieve what is on the picture.
I have got WLC 2504 and 2 access points 1702. Is it possible?
ammahend
you can do this without controller, convert both to autonomous mode, follow this post if you run into any issue converting to autonomous mode.
https://supportforums.cisco.com/discussion/12336596/how-convert-ap-1700-2700-lightweight-mode-autonomous-mode
once converted, you can configure one AP as root other AP as non-root, I would also recommend you to configure some form of security for instance non-root should authenticate through 802.1x with root before joining, using a local user database on root.
Follow the link below for configuration example.
http://www.cisco.com/c/en/us/support/docs/wireless-mobility/wireless-lan-wlan/68087-bridges-pt-to-pt.html
If you want to use controller you can do ethernet bridging over mesh, see the link below.
http://www.cisco.com/web/services/news/ts_newsletter/tech/chalktalk/archives/200911.html
I have personally done option 1 with a different AP model, keep in mind to take consideration RF parameters like EIRP, LOS etc for wireless bridging.
Rate helpful posts !
-hope this helps-
Sandeep Choudhary
yes you can achieve.
Check these posts:
https://rscciew.wordpress.com/2014/08/15/wgb-with-multiple-vlan-in-uwns/
http://www.cisco.com/c/en/us/support/docs/wireless/4400-series-wireless-lan-controllers/100254-wgb-config.html
Dont forget to rate helpful posts
