WLC - Flex connect - Block ACL
robbyde0100
Level 3
Level 3
We run a virtual WLC in our data centre and have a APs at local sites using flex connect.
We broadcast two SSIDs, a corpate one and a guest.
With guest, we use a ACL to block access until the users have logged into the portal via an ACL configured in:
Flex connect Groups > ACL Mapping > Policies.
Users at one site are bypassing he ACL by using Psiphon Pro VPN. How do stop this? DO I create a new ACL and add it to policies?
Rasika Nayanajith
Yes, if you can modify the exisiting ACL to block this VPN that would achieve the outcome.
Rasika
*** Pls rate all useful responses ***
