03-07-2018 02:58 AM - edited 07-05-2021 08:20 AM
We are testing the WLC 8.3 HA AP SSO switch over with command redundancy force-switchover . Failover happening from Primary to secondary active. although it reboots the primary !. is it expected ?. we are looking for fail over without rebooting the server
Solved! Go to Solution.
03-07-2018 03:15 AM
- Yeah , I always found this one confusing too as it 'only' reboots the active WLC perhaps it could have been given some better command-name.
M.
03-07-2018 03:06 AM
Yes its normal...
once you use redundancy force-switchover command on the Active WLC. This command will trigger a manual switchover where the Active WLC will reboot and the Standby WLC will take over the network.
Dont forget to arte helpful posts
03-07-2018 03:15 AM
is there any method to switch over to standby without reboot of the active one ?.
03-07-2018 03:19 AM
- I don't think so , the question is less-relevant ; if you want a real failover; the momentariliy-post-condition of the 'previous partner' is less relevant.
M.
03-07-2018 03:32 AM
shutdown the LAN port where active WLC is connected.!!!! (Just an idea)
Dont forget to rate helpful posts
03-07-2018 03:34 AM
- Personally I , wouldn't recommend such actions, because the HA going over other vlan, or network ; you may end up in split-brain conditions.
M.
03-07-2018 03:15 AM
M.
