WLC I am trying to setup lan connection
meliand93
My wlc is failing to connection to the internet with a lan configuration the wlc sees that something is plugged into a port. I'm not sure how the setting should be I have followed various guides to no avail, any help would be appreciated.
https://www.cisco.com/c/en/us/td/docs/wireless/controller/7-4/configuration/guides/consolidated/b_cg74_CONSOLIDATED/b_cg74_CONSOLIDATED_chapter_0110.html
https://www.cisco.com/c/en/us/td/docs/wireless/controller/8-5/config-guide/b_cg85/dhcp.html
Sandeep Choudhary
Step1: Connect WLC via console and do the initial config.....
example: https://www.networkstraining.com/cisco-wireless-lan-controller-configuration/
Step2: Connect to swicthport. and use these config for that swicthport:
Example:
interface GigabitEthernet2/1
switchport trunk allowed vlan 1,81,82,171,999
switchport mode trunk
no shut
Dont forget to rate helpful posts
Do I enter CLI then sign in and put those commands in?
How do I connect to switch port.
