WLC Installation
Sunil Patil
Level 2
Level 2
I have one WLC AIR-WLC4402-50-K9 which is hitting some bug. So I done RMA for that devices and now i got the new WLC.
Now i want to install that RMA WLC in network. So can any one tell me what is the process for installtion of WLC. I already have the old WLC in working now. So can you please tell which file backup i need to take from old WLC.
Sunil
Scott Fella
You need to backup the config from the existing and then upload to the new wlc. If you don't know how to perform an auto install, you will have to console into the new wlc and perform the initial setup. From there, you should be able to connect to the wlc and perform an upload configuration to controller.
Scott Fella
Sent from my iPhone
-Scott
Leo Laohoo
Hmmmm ... This two statements contradict themselves.  I've have NOT seen an IOS bug which requires an RMA.  The only reason one would RMA the WLC is when you have a component failure.
If you have a component failure, chances are you won't be able to successfully boot the WLC for you to backup the config.
satya mothukuri
Level 4
Level 4
Hi Sunil,
1st download the config file from the wlc.
2nd install the new wlc with basic config
Welcome to the Cisco Wizard Configuration Tool
Use the '-' character to backup
System Name [Cisco_b9:98:03]: XXXX
Enter Administrative User Name (24 characters max): admin
Enter Administrative Password (24 characters max): *****
Service Interface IP Address Configuration [none][DHCP]: none
Service Interface IP Address: 22   .2.2..   2   4
Service Interface Netmask: 255.255.255.25      0
Enable Link Aggregation (LAG) [yes][NO]: yes
Management Interface IP Address: 10.4.0.51
Management Interface Netmask: 255.255.255.252
Err: Network interface cannot be set to subnet broadcast Address
Management Interface Netmask: 255.255.255.0
Management Interface Default Router: 10.4.0.1
Management Interface VLAN Identifier (0 = untagged): 0
Management Interface DHCP Server IP Address: 10.4.0.1
Invalid response
AP Transport Mode [layer2][LAYER3]: layer3
AP Manager Interface IP Address: 10.4.0.52
AP-Manager is on Management subnet, using same values
AP Manager Interface DHCP Server (10.4.0.1): 10.4.0.1
Virtual Gateway IP Address: 1.1.1.1
Mobility/RF Group Name: x.x.x.x
Network Name (SSID): hpwl
Allow Static IP Addresses [YES][no]: yes
Configure a RADIUS Server now? [YES][no]: no
Warning! The default WLAN security policy requires a RADIUS server.
Please see documentation for more details.
Enter Country Code (enter 'help' for a list of countries) [US]: in
Enable 802.11b Network [YES][no]: yes
Enable 802.11a Network [YES][no]: yes
Enable 802.11g Network [YES][no]: yes
Enable Auto-RF [YES][no]: yes
Configuration saved!
Resetting system with new configuration...
this is a sample config....try to apply for your network. After the new wlc up then upload the old config file.
Regards.
Satya.M
