WLC issue
sateeshk10
Level 6
Level 6
I have a WLC 4400 model which is having 5 AP`s r connected.
Still friday it was fine. Sudenly there is issue with that getting the error that its always going to VALIDITY IDENTITY MODE and also getting the following error.
RADIUS server 172.16.10.31:1812 failed to respond to request (ID 150) for client 00:1a:73:f3:9d:fe / user 'unknown'
sateesh
Scott Fella
Are the AP's loosing connectivity? The error shows failed authentication of a users to the specified radius server. Post the VALIDITY IDENTITY MODE error you are seeing. If the AP's are getting that error, do you have validate AP to AAA enabled?
-Scott
HI,
Thanks for your prompt response. It seems to be prob with RADIUS server. my systems team is working on the same.
I appreciated your prompt reponse.
sateesh
We seem to be getting the same error msge too. It reads something like this
When IAS logging is turned on, the log file jumps in size very quickly, approx 8MB a minute, filled with the same message over and over: ,,IAS,,4128,wireless lan controller,25,311 1 30354085,4132,Secured password (EAP-MSCHAP v2),4127,11,8100,1,4130,0x4947454E2E4C4F43414C2F2142657468657364612F55736572732F4C6F6773646F6E2C2044656C656E61,4294967206,0,4294967207,1,4108,,4116,0,4155,1,4154,Use Windows authentication for all users,4129,,4149,authenticate wireless lan users with PEAP,4136,2,4142,0..."
What was SateeshK10 's final fix?
