wlc issue
meiyappan
Community Member
 i was cleared the ap stats , how to get again ap join status in wlc
aravinda099
Level 3
Level 3
Try using the GUI of the WLC. Under Wireless > Access Points > All APs  you'll see the inventory of your APs . Will show you the stats of each AP when you click on the AP. Hope this helps.
In order to rejoin the AP , Use the command
> config known ap { add | alert | delete} MAC
For more commands please go through
http://www.cisco.com/c/en/us/td/docs/wireless/controller/7-4/command/reference/consolidated/b_cr74_CONSOLIDATED/cr74_chapter_0111.html#wp1859229570
sobhardw
I would like to suggest you to please check the below link :
http://www.cisco.com/c/en/us/support/docs/wireless/4400-series-wireless-lan-controllers/99948-lap-notjoin-wlc-tshoot.html#req
Please let me know If the Solution is helpful.
