WLC missing files for Web Auth
We have 2 WLC 5520 configured as HA. One of them stopped working and was replaced with a new.
Now the Web Auth doesn't work if we have the new WLC active, we get 404 not found on the client.
If we switch active WLC and let the other that we haven't replaced be active the Web Auth works fine.
Why does the replaced WLC missing our customized login.html? How do we load the replaced WLC with our customized login.html?
2 Accepted Solutions
 Actually your problem does not make sense. But, you can try to load the file using the following procedure:
https://www.cisco.com/c/en/us/support/docs/wireless-mobility/wlan-security/115951-web-auth-wlc-guide-00.html#anc7
How to Configure a Custom Local WebAuth with Custom Page
I re-downloaded the WebAuth Bundle to the controller via the web interface and it was successfully installed on active and standby. Now it works fine when the replaced WLC is active.
