Dear Guys,
Currently i am building a WLC setup , where i setup two WLC in active / standby configuration. Currently i am using version 7.4.121.0 on all three controller. two for LAN and one is guest controller.
Active / Standy work fine But i am not able to see the mobility group work as it show " Control and Data Path Down"
i try to reboot the controller multiple time but still no success. Any body help will be appreciated
LAN controller can ping to Guest controller.
Following is the output from LAN controllers.
For Active / Standy some output .. like Redudancy , ping and mobility summary
(Cisco Controller) >show redundancy summary
Redundancy Mode = SSO ENABLED
Local State = ACTIVE
Peer State = STANDBY HOT
Unit = Primary
Unit ID = 18:E7:28:C0:57:00
Redundancy State = AP SSO
Mobility MAC = 18:E7:28:C0:57:00
Average Redundancy Peer Reachability Latency = 960 usecs
Average Management Gateway Reachability Latency = 676 usecs
Redundancy Management IP Address................. 10.23.120.13
Peer Redundancy Management IP Address............ 10.23.120.11
Redundancy Port IP Address....................... 169.254.120.13
Peer Redundancy Port IP Address.................. 169.254.120.11
Peer Service Port IP Address..................... 0.0.0.0
(Cisco Controller) >ping 10.23.120.12
Send count=3, Receive count=3 from 10.23.120.12
(Cisco Controller) >ping 10.23.120.50
Send count=3, Receive count=3 from 10.23.120.50
(Cisco Controller) >show mobility summary
Mobility Architecture ........................... Flat
Mobility Protocol Port........................... 16666
Default Mobility Domain.......................... GH-WLC-Wifi
Multicast Mode .................................. Disabled
Mobility Domain ID for 802.11r................... 0x52ef
Mobility Keepalive Interval...................... 10
Mobility Keepalive Count......................... 3
Mobility Group Members Configured................ 2
Mobility Control Message DSCP Value.............. 0
Controllers configured in the Mobility Group
MAC Address IP Address Group Name Multicast IP Status
18:e7:28:c0:57:00 10.23.120.12 GH-WLC-Wifi 0.0.0.0 Up
74:a2:e6:c6:89:20 10.23.120.50 GH-WLC-Wifi 0.0.0.0 Control and Data Path Down
Guest WLC output for mobility ( note Guest controller mangment IP can able to reach LAN controller "
Default Mobility Domain.......................... Guest-Wifi
Mobility Domain ID for 802.11r................... 0x91d7
18:e7:28:c0:57:00 10.23.120.12 Guest-Wifi 0.0.0.0 Control and Data Path Down
74:a2:e6:c6:89:20 10.23.120.50 Guest-Wifi 0.0.0.0 Up
