[WLC] Modify Flexconnect Management VLAN without changing Native VLAN
thibaut.matzke
Frequent Visitor
Frequent Visitor
I would like to modify the management VLAN of my 2702 Cisco AP without modifying the Native VLAN.
We are using a Centralized WLC to manage our APs, with AP groups and Flexconnect groups.
I managed to change the AP management VLAN by modifying the Flexconnect Native VLAN ID parameter, and also modifying the Native VLAN ID switchport :
What I would like to do, is to be able to only change the AP management VLAN without modifying the Native VLAN ID.
Is this possible ? Or does the AP management VLAN has to be the Native VLAN ?
Thank you in advance for your answers,
Rasika Nayanajith
It is not possible. AP management VLAN has to be native VLAN in FlexConnect
Rasika
*** Pls rate all useful responses ***
Rasika Nayanajith
Rasika
Hello Rasika,
Okay, thank you very much for your answer !
Best regards
