WLC Multi-Interface WLAN with static IP or DHCP reservations
Wes Schochet
Level 3
Level 3
We are in a hospital environment are are constantly running up against size limits on SSIDs.  The new Interface group feature seems like the perfect solution for our problem.  I do however have some devices on these SSIDs that have either a static IP address or a reserved IP based on their MAC address that gets assigned from DHCP.
I remember reading somewhere about the vlan / subnet allocation scheme, but I can't find it. I am concerned about the interaction here.  Is it possible that all devices are assigned to the first vlan / interface and only look for a second one if DHCP is full?  that seems too good to be true.
Any ideas or suggestions would be appreciated!
Stephen Rodriguez
The devices are assigned a MAC hash that's get stored on the WLC.  Addresses are issued in a round-robin approach from all the interfaces in the group.
  • If a client has a static IP configured in, for example, subnet A, and they are allotted subnet B, they will get moved to subnet A (override), before moving to the RUN state, if these conditions are met:
    • DHCP Required is disabled on the WLAN.
    • Subnet A is included in the VLAN or the AP group is configured on the WLAN.
    • The client sends some packet sourced with a static IP in subnet A within the DHCP_REQD interval (~ 2 min default value).
  • The DHCP_required interval is configurable and can have a maximum value of 120 seconds. Go to Controller > Advanced > DHCP Parameters > DHCP timeout (5-120 seconds).
  • If the static IP client has an IP address from a subnet that is part  of the interface group which is mapped to the WLAN, then the static IP  client that joins over that WLAN will move to a RUN state and can pass  traffic. Otherwise, the static IP client cannot pass traffic.
http://www.cisco.com/en/US/products/ps10315/products_tech_note09186a0080bb4900.shtml
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
HTH,
Steve
Thanks so much - this is exactly what I was looking for!
