WLC NAT Feature problem for OEAP
Dear all,
The problem that i have when i enable NAT on my MGMT interface, the APs on the "inside" does not find the WLC.
If uncheck the NAT the APs will connect right away.
When I enable the NAT, the APs stay connected but some them and from time to time they leave the WLC and join the backup WLC and back to main and and...
I also use the feature config network ap-discovery nat-ip-only disable
Code 7.6.130.0
I know it is better to use a separate WLC for OEAP, but the option is there and I would like to use it because we have not much OEAPs.
should I prevent the internal APs to be able to reach the external IP? I allowed only CAPWA to the NAT IP, is there anything we should change..?
best regards,
Sebastian
16 Replies 16
Ok, today we decided to block the ability for internal APs to join the public ip. I will see if that helps. I keep u in the loop.
The idea to add the mac's doesn't help.. :(
It was just a lucky hit in the moment I checked the WLC.
the command is used, but without success....at the Moment I have just two APs..we will see if the count grows...
