WLC not passing traffic for Apps
Ronald Steadman
We have installed a WLC with 5 access points.  Those APs broadcast 3 VLANs on different Subnets.  We are having an issue where one of those subnets is assigning IP addresses to devices over wired and wireless connections.  We are able to ping between those devices, but certain traffic is being blocked, such as visability between our digital mixing consoles and their respective IPAD controlling apps.
I don't know how to look through this issue.  Any help would be awesome!
Good to answer your question :)
I have encountered an issue with one client ( a bit different) and wanted to suggest you to enable multicast and broadcast. If you google youll find a doc for wlc config for apple devices. That was very useful u can chech it.
Rating useful replies is more useful than saying "Thank you"
6 Replies 6
Stephen Rodriguez
Generally this happens when ever you try to 'bridge' traffic from the wire to the wireless.
Try this:
config network mgmt-via-dynamic-interface enable.
Steve
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
That didn't work for any of the three apps.  It is interesting to me that this doesn't work with any of these three apps for three different types of network traffic.  Thanks, though, for the response!  I appreciate the help.
Ronald Steadman
Well.  I have never posted an answer to my own question. But after some research and getting wireshark involved, we found the steps to resolve our issue.  For clarity, this issue was related to the following devices and their respective APPs:
  • Yamaha M7CL-48
  • Presonus 16.4.2 and 24.4.2 with Universal Control and Qmix
  • ProPresenter 5 Remote Control and Remote Stage Display
In order to get these apps to work, we had to enable MultiCasting with an IP address, as well as enabling broadcasting traffic.  I hope that helps others as much as it helped me.
That did fix one of the issues, but enabling broadcast traffic solved the other one.
Thanks!
Thanks Ronald.
My issue was that  broadcast is enabled but not working! After about 6 months of troubleshooting we found that enabling broadcast does not work until u enable multicast as well.
