WLC not synchronize with NTP
jong_r0602
I need some help, I have configured my ntp server server in my WLC but i jut noticed that the time is not syncronized. I am able to ping the ntp server in my WLC. Appreciate if someone can help me to correct this problem.
Jong
Glad to help!
-Scott
10 Replies 10
Rob Huffman
Hi Jong,
There are some good examples and troubleshooting ideas in this doc;
NTP Configuration and Synchronization for Unified Wireless Network Devices
http://www.cisco.com/en/US/products/ps6366/products_configuration_example09186a0080811274.shtml#setup-wlc
Hope this helps!
Rob
Hi Rob,
I tried it but still not work. Please see the logs. My WLC is 4hr advanced on my ntp server.
Thanks for your time,
Jong
Try this.... On the WLC click on the Commands tab, then Set Time. Set the time zone you are in and hit Set Time Zone. Now set the time manually and hit Set Date and Time. Now click on the Controller tab and then NTP. Set the polling to 3600 and hit apply. Now you can change it back to 86400 or what ever time you want the polling to happen. this will force the time to be accurate.
-Scott
Wow! great its working now!
Thank you very much
-Jong
Glad to help!
-Scott
hi scott,
had a NTP sync issue on a new WLC and solved with your suggestion.
may i know if this is a bug or is this just the way WLC get stuck with NTP?
Hello scott,
How can i make C-9800-L wlc synched with NTP server. NTP server is showing unsynchronized from the WLC
The 9800 should sync automatically if the NTP server responds. You should try some external NTP to test and also make sure there is nothing blocking between.
-Scott
Thank you Scott !
Max Wooks
I also noticed this issue arise with the NTP authentication of servers that aren't at the top of the Server Index list. It would be stuck in "Sync Awaiting" forever until it's place at the top of the Server Index list. Then and only then will the NTP Authentication happen successfully. This is on version 8.5.160.0 on WLC 5508.
