WLC QoS settings
boshardy1
Level 2
Level 2
Hello all. I have a video surveillance system that must be able to be viewed on the wireless. It uses multicast and I have configured that appropriately (checked with tac). The response time is bad, camera images/frames per second very slow. So I think I need some QoS. I have made the SSID gold on the controller for QoS. What config do I need on AP ports, controller port, etc on my switches (mls qos trust cos or dscp?). Do I need to do anything else?
ericgarnel
Level 11
Level 11
This is what we have on the AP switch ports and uplink trunk ports:
mls qos trust dscp
This is what we have on the switchports to the controller:
qos trust cos
as well as vlan pruning of vlans that do not need to cross the trunk to the controllers
Also, under the controller QOS profiles, do you have 802.1p enabled?
Thanks, I changed my AP ports to dscp and did enable 802.1p. My concern is right now on the trunk ports it is set to trust cos. We are running Cisco voice, so I am not sure if I can change the trust on the trunks from cos to dscp, any thoughts?
this may help too:
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_tech_note09186a0080810880.shtml
Wireless LAN Controller (WLC) Configuration Best Practices
