WLC Security-->Priority Order --- pls Help
vudiep1735047
Pls help me
By default oder is  1. "LOCAL" , 2. "RADIUS"
i was change "RADIUS" up, and now i can not recnonect managerment WLC.
Pls hepl me.....
Rasika Nayanajith
You may have to temp disconnect your WLC from network & then it should fall back to Local. Then you should be able to revert config.
Otherwise if you haven't save your configuration, the simple reload of WLC should revert your configuration
Rasika
*** Pls rate all useful responses ***
Rasika Nayanajith
Rasika
Thank, but i was apply this config.
I fixed, by the way connect direct my Laptop with WLC, and i can login and config angain.
Failing that I find that if you remove the client device from ISE's Device list, then ISE won't respond to the client, and hence, the WLC will fail through to LOCAL again. It works for TACACS too.
