WLC - SNMP settings
luisbicalho
Community Member
I would like collect information from Access Points using SNMP. My application to do a snmp get for each device.
These APs are connected with a WLC and this WLC has the SNMP credentials to read/write configured.
Is possible replicate the SNMP configs from WLC to all APs or I need to set SNMP credentials for each AP?
Thanks for the help.
Nicolas Darchis
You cannot SNMP to APs if they are controlled by a WLC.
The WLC has in its MIB all the needed info about all the APs.
Hi Nicolas,
Thanks for the information.
