WLC WEB Authentication Certificate installation error
maldafee
Frequent Visitor
Frequent Visitor
Dear Sir,
I tried to download and install 3rd party certificate to WLC SW v 7.6.110
I followed the steps as this link said
https://www.cisco.com/c/en/us/support/docs/wireless/4400-series-wireless-lan-controllers/109597-csr-chained-certificates-wlc-00.html
and when I tried to download it to WLC, it gives me this error:
Error installing certificate.
This is the debug output:
*TransferTask: Mar 23 09:35:12.337: Memory overcommit policy changed from 0 to 1
*TransferTask: Mar 23 09:35:12.337: RESULT_STRING: TFTP Webauth cert transfer st arting.
*TransferTask: Mar 23 09:35:12.337: RESULT_CODE:1
TFTP Webauth cert transfer starting.
*TransferTask: Mar 23 09:35:16.337: Locking tftp semaphore, pHost=10.22.21.127 pFilename=/final.pem
*TransferTask: Mar 23 09:35:16.421: Semaphore locked, now unlocking, pHost=10.22.21.127 pFilename=/final.pem
*TransferTask: Mar 23 09:35:16.421: Semaphore successfully unlocked, pHost=10.22.21.127 pFilename=/final.pem
*TransferTask: Mar 23 09:35:16.421: TFTP: Binding to remote=10.22.21.127
*TransferTask: Mar 23 09:35:16.439: TFP End: 9013 bytes transferred (0 retransmitted packets)
*TransferTask: Mar 23 09:35:16.439: tftp rc=0, pHost=10.22.21.127 pFilename=/final.pem
pLocalFilename=cert.p12
*TransferTask: Mar 23 09:35:16.439: RESULT_STRING: TFTP receive complete... Installing Certificate.
*TransferTask: Mar 23 09:35:16.439: RESULT_CODE:13
*TransferTask: Mar 23 09:35:20.441: Adding cert (8941 bytes) with certificate key password.
*TransferTask: Mar 23 09:35:20.472: sshpmCheckWebauthCert: Verification return code: 0
*TransferTask: Mar 23 09:35:20.472: Verification result text: unable to get issuer certificate
*TransferTask: Mar 23 09:35:20.472: Error at 2 depth: unable to get issuer certificate
*TransferTask: Mar 23 09:35:20.485: sshpmAddWebauthCert: Error decoding certificate, Deleting it.
*TransferTask: Mar 23 09:35:20.485: RESULT_STRING: Error installing certificate.
*TransferTask: Mar 23 09:35:20.485: RESULT_CODE:12
*TransferTask: Mar 23 09:35:20.485: Memory overcommit policy restored from 1 to 0
Any idea to solve this problem..
Mark Elsen
 - You may find this document useful : https://www.cisco.com/c/en/us/support/docs/wireless/wireless-lan-controller-software/215425-troubleshoot-certificate-installation-on.html  , note also that controller software version is very old , use modern release if possible.
 M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
