WLC web authentication
alex goshtaei
Level 7
Level 7
Hi All,
we are trying to import CA certificate on four WLCs for guest web authentication. We already have one CA certificate with common domain domain which all WLC use the same domain. so I need to import cert with WLC private key. is it possible to append private key  to CA cert and import to the WLC? I need to install OpenSSL to generate private key and CSR file, do I? is there any easier way?
thanks
Alex
0 Replies 0
