WLC - Wlapp configurations problems
Yamani313
Community Member
I have connected the WCS to Wlc and WLC to AP
after giving the WLC basic configurations and AP management ip add, still i can not see the AP from the controller.
should I configure each ap manually and give it an ip add ? or it is enough to put the AP management ip add in the controller?
If you can actually manage the WLC using the WCS, you can "force" the WCS to "discover" the AP attached to this WLC.
Simply, in Controller tab, select your WLC and in the upper right list select "refresh config from controller" and GO, then WCS ask you if you want to keep the configuration of the WLC stored in WCS database or "refresh" it deleting the actual configuration; check delete and Go.
Finally, You can review if the AP now is shown by the WCS or not.
Best Regards.
Best Regards.
