WLC
mukeshcu1
Community Member
We are using Cisco WLC. I want to give delegation of WLC, Like adding mac address,user creation etc to my L1 team.. Is there any way for achieving this..
Thanks in advance..
You can use roles if using TACACS:
http://www.cisco.com/c/en/us/td/docs/wireless/controller/7-5/config_guide/b_cg75/b_cg75_chapter_0101001.html
You can't specify what they can and can't do though. You limit what tabs on the GUI they can access.
Scott
-Scott
5 Replies 5
Scott Fella
The only other way is to create a lobby ambassador account, but you need to know what they can do and can't.
http://www.cisco.com/c/en/us/td/docs/wireless/controller/7-0/configuration/guide/c70/c70users.html#wp1048412
You can also use radius or tacacs if you have it to limit what tabs on the GUI a user can have access to.
https://supportforums.cisco.com/document/57301/wlc-and-acs-5x-tacacs-configuration-example-web-authentication
Scott
-Scott
Hello Scott,
Thanks for revert.
I have gone through the link which you provided but its not mentioned anywhere, How to limit the GUI interface tab..
I have created the lobby ambassador account and i can only get the option for adding / deleting guest account..Please help how can i assign other privileges like mac filtering, health monitoring etc.
Scott
-Scott
Thanks Scott.
Abha Jha
You may select the following roles using TACACS :-
MONITOR, WLAN, CONTROLLER, WIRELESS, SECURITY, MANAGEMENT, COMMANDS, ALL, and LOBBY. The first seven correspond to the menu options on the controller GUI and allow access to those particular controller features. If a user is not entitled for a particular task, the user is still allowed to access that task in read-only mode. You can enter one or multiple roles, depending on the group's needs. Use ALL to specify all seven roles or LOBBY to specify the lobby ambassador role.
