WLC
mrivas
Community Member
Hello, I can help with these questions please:
1 - How to Validate the 5508 WLC version 7.6 can interoperate with ACS version 4.2.?
2 - You can enable or situation FlexConnect with previous validation?
thank you
Leo Laohoo
Not going to be easy if you don't have a dedicated authentication server at the site.
With traditional connection (non-FlexConnect), when your LAN or WAN link (to the WLC) goes out, the APs can't do anything.  Clients will loose connection.  With FlexConnect, when the WAN link to the WLC goes out, current clients will still be connected to wireless, HOWEVER, you need a dedicated authentication server so the wireless can accept NEW wireless clients.
mohanak
RADIUS is supported on CiscoSecure ACS version 3.2 and later releases. See the CiscoSecure ACS documentation for the version that you are running.
http://www.cisco.com/c/en/us/td/docs/wireless/controller/7-2/configuration/guide/cg/cg_security_sol.html#wp1976245
Interoperability With Other Clients in 7.2.111.3
This section describes the interoperability of the version of controller software with other client devices.
Table 1-4 describes the configuration used for testing the clients.
Table 1-4 Test Bed Configuration for Interoperability
Hardware/Software Parameter
Hardware/Software Configuration Type
Release
7.2.111.3
Controller
Cisco 5500 Series Controller
Access points
1131, 1142, 1242, 1252, 3500e, 3500i, and 3600
Radio
802.11a, 802.11g, 802.11n2, 802.11n5
Security
Open, WEP, PSK (WPA and WPA2), 802.1X (WPA-TKIP and WPA2-AES) (LEAP, PEAP, EAP-FAST, EAP-TLS)
RADIUS
ACS 4.2, ACS 5.2
Types of tests
Connectivity, traffic, and roaming between two access points
