wlc
Anjana A
Level 4
Level 4
command to check the intrefrence in cisco 9800 wlc for a specific ap
Mark Elsen
  - Interference is not related to a specific AP but 'belongs' to the surrounding environment , have a look at :
    https://www.cisco.com/c/en/us/td/docs/wireless/controller/9800/17-3/config-guide/b_wl_17_3_cg/m-161-ca-3850-3650-cg.html   which offers equipment and methodologies to deal with interference,
   M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
Scott Fella
Can you define what you really want to see?  Typically there are other tools that  can help with discovery and troubleshooting of interference, but there are some options with newer access points that you can utilize.  Look also at what @Mark Elsen posted, but you need to know what exactly you are looking for.
-Scott
